A/C Delete?
Old Oct 27, 2011 | 01:07 AM
19BLACKBIRD99's Avatar
Default A/C Delete?
Needing to know what all I need to do to completely remove my a/c. Not sure if this is the right thread to post this but if anyone can help out, please let me know!
Old Oct 27, 2011 | 01:24 AM
lusting4ls1's Avatar
depends...do want to delete everything? Like the heat and the blower motor and all that? If so you will have to pull the dash and take out the box. If you are just wanting to remove the ac components, most people just bash off that black box under the hood and take the ac condensor out. Then put an ac delete plate over the hole and remove the rest of the components from under the hood.
Old Oct 27, 2011 | 01:30 AM
I'm really just wantif to remove everything under the good, and keep my heat. Just remove some un needed weight
Old Oct 27, 2011 | 02:05 AM
bww3588's Avatar
Cut the box flush with the firewall and remove the evaporater and make a block off plate. Make sure its sealed really well or your heat won't work worth a ****.
