Unknown connector
Old Nov 12, 2011 | 06:56 PM
MFCptnMorgan's Avatar
Default Unknown connector
Not sure if this is the right section but my car threw an o2 code for right side. So i get under there to fix it and find out the connector melted on the header. Not that big of a problem while fixing this a connector came unplugged somewhere over the starter and its causing the car not to start it turns over but won't crank just seeing if anyone knows what the connector goes too. Thanks, Morgan
Old Nov 12, 2011 | 07:04 PM
I believe it is the crank position sensor. Where on the motor is it located thanks
Old Nov 12, 2011 | 07:12 PM
camaroz28lt1at's Avatar
Thats your CPS, (crank position sensor). Its located right above the starter, close to the rear of the motor.
