241 or 243
Old Nov 15, 2011 | 09:29 AM
MFCptnMorgan's Avatar
Default 241 or 243
Gonna be doing a head swap sometime in the near future nothing to big just gonna get a set of gm heads. I have a 99 camaro ss full bolt on looking at either 241 or 243 heads just wanted to get some pros and cons. Thanks morgan
Old Nov 15, 2011 | 09:32 AM
ANTICOP RAM AIR's Avatar
https://ls1tech.com/forums/generatio...243-heads.html
Old Nov 15, 2011 | 09:47 AM
thunderstruck507's Avatar
241 will be basically the same as what you have on your 99, not worth changing.
Honestly I wouldn't even put on 243 unless they were at least mildly ported.
Old Nov 15, 2011 | 07:43 PM
mike c.'s Avatar
If your low on cash,find a used set of AFR 205 heads. The quality and performance of them is out standing. You will make a better gain.
Old Nov 15, 2011 | 07:59 PM
midevil1's Avatar
Stage 2.5 5.3 heads.
Old Nov 15, 2011 | 08:15 PM
COPO9560's Avatar
Your 99 should have 853 heads. These can be ported by AI just like the 241 heads and get you a good gain in power for minimal cost.
241 is basically the same head you have port wise. 243 will make more power stock but ported all 3 are very close.
Old Nov 15, 2011 | 08:16 PM
Sales1@Texas-speed's Avatar
If your going to go through the trouble of swapping cylinder heads I would recommend making it worth your wild. Send the heads out for cnc work, valve job, and milling if your ptv clearance allows for it. This will net you some very nice results and be well worth the time and money invested.
Old Nov 18, 2011 | 10:13 PM
mike c.'s Avatar
And so will a set of AFR heads. Ran close to 10's na in a 3,700lbs car,m6 and a 26 in cheeter slick. Heat,leather,power everything full interior.
Old Nov 18, 2011 | 10:54 PM
MFCptnMorgan feel free to give me a call I would be happy to help you out with any questions you have.
