Post and pre cat oxygen/o2 sensors the same?
Old Nov 16, 2011 | 12:43 PM
Don Nguyen's Avatar
Default Post and pre cat oxygen/o2 sensors the same?
I have an extra set of O2 sensors, but I can not remember if they were post or pre cat o2 sensors. I was wondering if they are the same part number/sensor?
Old Nov 16, 2011 | 12:51 PM
OnyxY2KSS's Avatar
The fronts should have a square pigtail and the rears should have a wider rectangular pigtail.
Old Nov 16, 2011 | 07:06 PM
skopers3's Avatar
You sure? I'd almost swear after I deleted my cats I used a rear to replace a front one that went bad it worked jsut fine...
Don Nguyen's Avatar
Kragen is showing the same part numbers for both o2 sensors being the same, so I will assume that they are.
-Don
Old Nov 16, 2011 | 08:42 PM
senicalj4579's Avatar
The part #s are different but they are totally the same except the wire length.
Old Nov 16, 2011 | 08:47 PM
LS6427's Avatar
Sensors and plugs are IDENTICAL....you can use any sensor in any position.....different wire lengths are why they have different part numbers. So measure and buy whatever sensor or brand you like.
I cut my rear plugs off and spliced them into my front wiring harness because my front plugs cracked. They are identical.
Old Nov 17, 2011 | 08:54 AM
omarrakeen's Avatar
agreed, i reused both rear when fronts went bad. other than the wire length they are the same.
