What Sensor is this? Sits on Intake for a LM7
I'm wiring up a Megasquirt 3 on 05+ LM7. I need to know what this sensor is / does.
See picture.
Also I don't want to run the MAF cause I don't need it but I need IAT (intake air temp) which is integrated into my MAF what is my best option on how to run a single IAT without using the MAF with integrated IAT.
Thanks in advance!
Since I'm not using the MAP sensor (megasquirt has one built in on unit) I'm thinking i will just install the IAT in the whole left open by removing the MAP.
Edit: probably not an issue with a stand-alone.
Rockauto for the IAT, althought the Megasquirt probably expects a sensor with a specific resistance curve. Either way, it should be pretty cheap. The LS1 IAT was like $13 shipped.
Just a suggestion, but Id leave the MAF on to atleast set a base tune. Unplug it later if you want it gone
FYI, you have to have either MAF or MAP. Cant delete both
