who makes best poly mounts?
Old Nov 24, 2011 | 11:54 AM
02ws.sik's Avatar
Default who makes best poly mounts?
Im going to get poly motor and tranny mounts. Who makes the best ones. I dont care if these are cheaper i want the best ones. Thanks Justin
Old Nov 24, 2011 | 12:02 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Prothane for the trans, hands down. Easiest mod to date. They also don't have an extra plate to worry about like the energy suspension ones.
For Motor mounts, I went Spohn solids, so I really can't help you there.
Old Nov 24, 2011 | 04:05 PM
sjsingle1's Avatar
i have prothane MM and tranny............no complaints
Old Nov 24, 2011 | 05:48 PM
02ws.sik's Avatar
What brand?
Old Nov 24, 2011 | 06:20 PM
LS1121's Avatar
Originally Posted by 02ws.sik
What brand?
Google....... Hyperflex, and get a Rubber tranny mount.
Old Nov 24, 2011 | 06:37 PM
02ws.sik's Avatar
Rubber why not poly
Old Nov 24, 2011 | 07:08 PM
Stippy17's Avatar
Prothane IS the brand.
Rubber why not poly
You'll feel alot of vibrations when using poly mounts over rubber mounts. A lot of people suggest running poly motor mounts, and rubber tranny mounts to reduce the vibrating while still being able to run stronger engine mounts.
Im redoing my exhaust this winter and I am replacing my motor/tranny mounts with OEM rubber. I daily drive my car and I dont want to deal with any vibrations. If the stockers lasted 56k and at my power level Ill be fine using them again. Only reason I am replacing them is because Im installing new headers and I might as well do the motor mounts while Im in there for maintenance reasons..
Old Nov 24, 2011 | 07:23 PM
2000PewterT/A's Avatar
I have Prothane motor mounts and trans mount and I have had no problems at all.
Old Nov 24, 2011 | 08:00 PM
LS1121's Avatar
Rubber why not poly
Because it was explained to me this way, and this is what i did. Everyone makes their own choice.
Chevy installed rubber mounts to cut down on Vibration. Poly Mounts Transfer more vibration. Use a rubber trans mount because it is right under your *** and you can feel everything.
Now on my car i can feel the vibration from the motor and it is not too bad, but this is my DD and i want to be as comfortable as possible. If you are not too concerned with vibration.....that is up to you.
Old Nov 24, 2011 | 08:56 PM
02ws.sik's Avatar
So pmm and stock mounts on tranny are ok together? How hard is it to install motor mounts on a car lift? I kind of is a dd but its like i only drive it on nice and when i dont have to park in parking lots.
Old Nov 24, 2011 | 10:26 PM
MI-Z/28's Avatar
Removing the stock mounts and installing the new mounts is easy. Difficult part is getting the motor to line back up with the new mounts. You might get lucky, but chances are you'll need a friend with a breaker bar to move the motor around a bit to get everything to line up.
Old Nov 24, 2011 | 11:32 PM
85CamaroZ28's Avatar
I should have my poly prothane motor mounts and stock rubber trans mount in tom. I'll let you know how they work.
Old Nov 24, 2011 | 11:42 PM
LS1121's Avatar
What he said.......oh yea!
Old Nov 25, 2011 | 09:44 AM
VandykeT/A's Avatar
If your a M6 you'd be fine with a poly trans mount. Both of my cars have them and I couldn't tell a difference. I think the vibration is an auto thing.
