water pump pulley
Old Nov 26, 2011 | 09:25 AM
srv8800's Avatar
Default water pump pulley
the pulley on my water pump spun apart at the weld. I've never seen that happen before.. can you replace just the pulley? all the water pumps I see come w pulleys already and I can't find replacements. will an electric pump hold up to daily driving? reason I ask is bc the blower likes to snap the belts every once and a while and it would be nice to still have a water pump. thanks
Old Nov 26, 2011 | 09:27 AM
srv8800's Avatar
this is on a 408 built from an iron block 6.0 btw.. sry
Old Nov 26, 2011 | 12:37 PM
sjsingle1's Avatar
stock pulley is pressed on........no removal.......you can buy WPs that have bolt on pulleys....like eldebrock
Old Nov 26, 2011 | 07:48 PM
Rikoshay's Avatar
It used to happen quite often a few years ago. ACDelco's supplier was having issues with the welds and had to revise what they were doing. Seen quite a few in the warranty bin for broken welds.
Old Nov 26, 2011 | 10:12 PM
sjsingle1's Avatar
where is the weld? the bell housing looks to be a 1 piece design
Old Nov 28, 2011 | 12:18 AM
gMAG's Avatar
A replacement I recently ordered came with the pressed on pulley.
I saved the pulley from my previous pump. It bolts on and has no welds that I can see.
