Intake set up question????
Old Nov 30, 2011 | 07:11 PM
jebuzws6's Avatar
Default Intake set up question????
Is there an intake fitment guide anywhere on tech? I want to to see what intake set up combinations will fit with each other. i.e.:
lid(xx mm)+maf(xx mm)+TB(xx mm)+ intake (xx mm)
any input would be greatly appreciated.
My idea for now is to run a TB 92mm with the rest of the stock units, but will that cause a problem?
Old Nov 30, 2011 | 08:38 PM
95LTXZ28's Avatar
I would also like to know this!
Old Nov 30, 2011 | 09:38 PM
dodson55's Avatar
Will it work yes but why would you spend all that money and leave everything else stock I wouldn't expect much hp gains
Old Nov 30, 2011 | 10:45 PM
Blk98Vert's Avatar
You can leave it stock before the MAF but again I don't see why. SLP MAFs are really cheap even the Delphi truck MAFs are cheap and a 98mm lid isnt much more than a normal lid
Old Dec 1, 2011 | 12:07 AM
95LTXZ28's Avatar
I always thought aftermarket mafs were nothing but a gimic and make it harder to tune. Just what I heard no personal experiences...
Old Dec 1, 2011 | 02:43 AM
Blk98Vert's Avatar
Aftermarket stock sized MAFs are, not the 85 and 100mms
Old Dec 1, 2011 | 07:25 AM
dodson55's Avatar
My opinion the lid and maf need to be the same size or bigger then the tb or you are loosing flow and leaving power on the table if you are going to spent the grand or more to get the intake and tb why not spend a couple hundred more and get a lid and maf or a SD tune
Old Dec 1, 2011 | 10:36 AM
jebuzws6's Avatar
ok.. well i think i am going to upgrade the MAF and lid aswell, dont have money for the intake right now so I think i will go with a 98mm lid+ 100mm MAF+ 92TB??? will that work with the LS6 intake for now?
 Michael S. Palmer
