02 Trans Am - EGR or not?
Old Dec 9, 2011 | 02:39 PM
maxpower_454's Avatar
Default 02 Trans Am - EGR or not?
I unfortunately live in an area that has visual emissions and I just bought a 02 Trans am. I read in the sticky that 01-02 didn't have EGR??? Is that true? I just don't see how it can be. I think every car has an egr
Old Dec 9, 2011 | 03:31 PM
99Bluz28's Avatar
True, 01-02 no EGR!
Here's the EGR on a 99:
http://www.myls1.com/howto/ls6intakeinstall/3.jpg
Old Dec 9, 2011 | 04:32 PM
ramairetransam's Avatar
gm made the cam smaller and added a better intake , the ls6 intake so power went up and emissions went down or stayed the same as the 98-00 so things are good . Your fine . And you already have the ls6 intake so theirs 350 bucks less in mods to buy .
Old Dec 9, 2011 | 07:44 PM
Guitar's Avatar
(These are the headers I have on my WS6, Dynatech Supermaxx Headers) So, just curious, what are the things on the top of these headers? I figured they were for EGR. My TSP 1 7/8 headers don't have them, so was curious what I was going to need to delete.
Did the 01-02 have the AIR system? I was planning on deleting that too.
Old Dec 9, 2011 | 08:29 PM
joecar's Avatar
The two top fittings on those headers are for the Secondary AIR system.
The single fitting on the passenger side header is for EGR; this is plumbed to the EGR valve/solenoid which plumbs to the intake manifold (immediately after the throttle body).
2001/2002 do not have EGR (you will see that the intake manifold has no port, see pic linked to by 99Bluz28 above which shows EGR tube going to 1998/1999/2000 intake manifold).
Those headers are for 1999/2000 F-body as it has the driver side AIR fitting is on primary #1;
the 2001/2002 headers have the driver side AIR fitting on primary #3, see pic here:
Old Dec 9, 2011 | 08:31 PM
Guitar's Avatar
Ahh, okay. Good to know, appreciate the explanation. So when I install my TSP headers, I'd have to delete the AIR system (even if I didn't want to)? I don't know why the PO decided to keep it, but whatever. Probably easier.
Old Dec 10, 2011 | 05:05 AM
Ronny_02_WS6's Avatar
Correct, TSP are reach style headers so they don't have AIR, here's a link on a thread that I did to remove the AIR https://ls1tech.com/forums/new-ls1-o...air-tubes.html
You have to delete the AIR with a tune so the SES light won't stay on.
Old Dec 10, 2011 | 10:43 AM
I need to reinstall my emissions stuff so I can pass emissions for the first time. It's just a visual and gas cap check so I guess I just need an air system. After the first time I'll be exempt if I drive under 5000 per year.
Old Dec 10, 2011 | 10:44 AM
Anyone have an air system for an 02 they Want to get rid of?
Old Dec 10, 2011 | 12:11 PM
99 PROBLEMS's Avatar
PM sent on system!
Old Dec 11, 2011 | 03:48 PM
AmarilloWS6's Avatar
The things sticking out of the headers are for your AIR and EGR system, I just got done ordering plates to put up top of them this morning to block them off.
