I need an LS intake tutorial
it will be NA, prob stick with auto since the car is auto now and don't want to go through all the t56 changeover yet. would like to put in a good cam, decent intake, maybe mildly p&p heads- fairly tame, looking for reliability and fun as a weekend cruisin/going to shows car.
Yes all OE gen III heads are cath ports. So choose your casting there. The truck manifold will work fine if you get it with your engine. Depending on your motor mount choice in the third gen you might be tight with hood clearance (im doing a third gen). The truck manifolds are designed for trucks therefore they offer more tq and less on the high end, but if its "free" then hey. If you want to spend some money get a cheap ls1 manifold or more money on a FAST.
On the engines, miles really dont tell alot especially when your surfing through ebay. Some higher mile motors are real gems and a ready to be slapped in and ran, others not so much but the same can be said for a lower mile motors. It would be ideal to see what you want in person or really trust the seller and talk to them one on one. I bought two 5.3s, one 130k and one 67K. Both turned over by hand and I was told ran fine. The 130 was great and just needed a freshen up but the 67 had a spun bearing and a bend rod...
Also have you given any thought to running a carb? This makes running an ls much more simple (in my opinion). No messy wiring and no computer tunning issues and there are options on intake manifolds as well. Personally I went with a carbed lq9 with l92 heads. Slightly more expensive but nice hp for the $.
so, you think the 5.3 truck intake will fit factory thirdgen hood? assuming acc mounting would need to be changed to fbody type stuff. ls1 intakes are cheap, no power gain i know really but solve the clearance deal. finding several 5.3's, most without harness- but is price is right....
