Front O2 Sensor Question
Old Dec 26, 2011 | 10:34 PM
Silver2000WS-6's Avatar
Default Front O2 Sensor Question
I am trying to wire up a '99 LQ4 in my brothers tube buggy. I am using the factory harness and unfortunately someone has cut the passenger side O2 wires. So I no longer have the connectors for that side. Looking at the driver side, the front O2 sensor carried a flat, four pin connector.
My question is: I have a set of '02 LS1 fbody front O2's "square pattern, four wire connector" and extension wires with connectors. Could I just do a way with the original "flat" style connector on the driver side and wire in the ends of the extensions I have and then use the fbody O2's on both sides? If not it appears I will have to buy another "flat" style connector and two matching O2's. I am just not sure if the "signal" from these O2's would be interchangeable. Thanks for any help.
Chase
I also posted this into the Conversion section, so just ignore it if you see it twice.
