Air Intake Options
Old Jan 1, 2012 | 08:06 PM
mbaker3's Avatar
Default Air Intake Options
I am just about done gathering everything to upgrade my 2002 6.0L Camaro to a 85mm MAF, 92mm FAST TB, LS3 intake, LS3 Heads and cam upgrade. What I am looking for now are options for my air intake. I have a SLP lid but would like to know if there is anything else available to help flow more air. I did find the K&N inlet filter.............is there anything else?
Old Jan 1, 2012 | 08:16 PM
sepsis's Avatar
You put a 6.0 in there?
Old Jan 1, 2012 | 08:26 PM
mbaker3's Avatar
Yes I have the LQ9 iron block in it because I might go with boost later.
Old Jan 1, 2012 | 08:33 PM
Blk98Vert's Avatar
FTP 98mm lid. The 85mm MAF will slide inside so it will be a smooth transition. Also I believe the lid has 20% more flow than a normal lid
Old Jan 1, 2012 | 08:36 PM
mbaker3's Avatar
Any hood clearance issues? I still have the stock Z28 hood and will be going to the VFN Sonoco hood next, but not until after the engine build.
Old Jan 1, 2012 | 08:40 PM
Blk98Vert's Avatar
No worse than any other lid according to FTPs site
Old Jan 1, 2012 | 08:44 PM
mbaker3's Avatar
Great!!! Thanks for the heads up on that. i just had not run across anything larger than the SLP lid and it is a lot smaller than the 85mm MAF. I will look it up!
