ground clerance w/ thunderbolt cats
Old Jan 2, 2012 | 12:48 PM
Thule's Avatar
Default ground clerance w/ thunderbolt cats
i am goin to install two thunderbolt catalysts on my ORY,
my car is lowered 1.2"+hose modd, and sits lower then i thougt
the Y pipe is just few inches from the ground, and i am afraid it will be undrivable, are there any smaller cats out there?
Old Jan 2, 2012 | 01:34 PM
sepsis's Avatar
what's the hose mod?
They have emissions testing in Iceland?
Old Jan 2, 2012 | 03:41 PM
99Bluz28's Avatar
Most bullet cats are about 4" diameter, so if your pipes are 3" then in a perfect world you'd lose 1/2" of ground clearance. Now if you don't currently have about 5/8" of clearance above the 3" pipe where the cat/s will be located then you'll either need to clearance the undercarriage for more room, or adjust the pipe/s lower resulting in additional lose in ground clearance. The clearance issue will most likely be on the drivers side.
FYI, with short section of thick metal plumbing pipe 3-5" OD and a jack you can clearance the undercarriage, by very slowly jacking the pipe up against the body multiple times while watching, and listening to the progress.
Old Jan 6, 2012 | 06:12 PM
Thule's Avatar
thanks man,
i guess i got to measure the clearence from the pipe to the floor, guess i will try this, and buy another ORY to throw in, still cheaper than the flowpack,
yes of course we hafe emission tests here
