removing A/C
Old Mar 16, 2004 | 10:35 PM
M6HuggerSS's Avatar
Arrow removing A/C
has anyone pulled it all? if so how much HP did you gain?
Old Mar 17, 2004 | 10:15 AM
Larry's Avatar
Don't know that you will gain any hp by removing the ac as the pulley on the compressor is free wheeling when off. You will lose about 32 pounds of weight off the front end when all ac components are removed from under the hood. More if you go into the under dash area.
Old Mar 17, 2004 | 11:25 AM
z98's Avatar
z98
Doubt you will gain any.
I believe the A/C has a clutch that disengages under WOT.
