PCV delete, Breathers
But I also have a single hose running from my passengers valve cover to my vacuum port on my intake. The TB port is capped off.
I have a needle valve right before my PCV valve in that single hose that I have turned way down, so it sucked just the perfect amount of crankcase gasses, but not too much, I don't get a drop of oil into my intake.
My experience playing around with different combos....the LS6 valley cover I have is GARBAGE. If I hook my vacuum line to that port with the PCV valve in line, oil flys through it like a Chinese bullet train. It pulls the oil mist right out of the crankcase.
The normal way vacuum is pulled without a valley cover, from the factory, is way to strong....the needle valve is perfect to turn down that vacuum force. Factory pull is way too much, its unecessary. If I put a cigarette near my filter on my drivers side valve cover, the smoke gets slightly sucked in so I know I have fresh air crossing my entire engine and getting pulled into the intake. But I have zero oil going through.
I don't have a picture yet with my needle valve and my valley cover port filter......but you can see what I have and what my final set up looks like.
i will eventually run a leak down test if ya'll think it could be a blown head gasket or cracked head. Im hope'n its just moisture in the oil
If you have allot of water shooting out the exhaust you will simply see the coolant lever drop over a few days time......if its a blown head gasket.
Sometimes I get water shoot out of the exhaust pipes because moisture has accumulated inside the exhaust system over night......
http://en.wikipedia.org/wiki/Crankca...ilation_system
Back in the 50's road draft tubes (in lieu of PCV) were what was used.
