PCV routing, is this ok for temp/a while
Old Jan 12, 2012 | 04:18 PM
3rdCoastPowerSports's Avatar
Default PCV routing, is this ok for temp/a while
regular 90* PCV in rear drivers side valve cover, 3' or so of 3/8" fuel hose running from the PCV valve at rear drives side valve cover to the lower nipple on the intake behind the Throttle body. cap on the rear passenger side valve cover nipple. air line from top nipple on intake to front of passenger valve cover nipple. regular fill tube and regular filler tube cap.
Will this be ok?
Old Jan 12, 2012 | 05:01 PM
mean_greenZ's Avatar
Yep that will do.
Old Jan 12, 2012 | 07:47 PM
Originally Posted by mean_greenZ
Yep that will do.
thank you sir
