FAST intake/Vring Question
Old Jan 14, 2012 | 09:51 PM
Munz's Avatar
Default FAST intake/Vring Question
I have purchased a ported FAST 102 from vengeance and had a LS2 DBW TB ported by Vmax and had a Vring sent out with it to suit.
Vengeance ported the mouth of the intake and the recommendation is to loosen the 2 front bolts and slide the Vring in and tighten the bolts.
So because of the mouth porting, when I install the Vring it slides in and out of the mouth... without loosening the bolts,
I haven't exactly measured but its safe to say it hasn't been ported to more than say 102.5-103mm as the Vring still contacts with the mouth somewhat.
I know it won't enter the intake but I'm worried about it moving back and forth and hitting the MAP sensor.
My question: Is there something I could line the mouth of the intake like silicon or similar that won't melt due to the extreme heat that engine will produce so the Vring won't move around?
Also I don't want to try and tighten the intake down anymore than it is as it may crack..
Thanks in advance for your help
Old Feb 11, 2012 | 08:28 AM
FlamingTA's Avatar
Sorry, can't help but thanks for posting this. I was thinking about getting one of those rings for my Vengeance port fast and ls2 TB until I saw this. Man I wish the DBW TB's weren't so expensive, my little 421 could use one.
Old Feb 11, 2012 | 08:49 AM
Undertow74's Avatar
Vengeance ported my intake aswell, and i have the same problem. Im just not going to use the ring and we will see how it goes. So with that said i have a useless vmax ring if anyone wants it.
I just dont like the idea of having to put something around the ring to get it to fit snug in there. even if i was to put a layer of tape around the ring to make it fit snug in there, i would hate for the **** to come off and get sucked through my intake
Old Feb 12, 2012 | 05:59 PM
Munz's Avatar
I'm gonna give it a few drops of RTV sealant like the high temp Copper Permatex one. Its got a higher temp range than the red silicon and is also sensor safe.
Can't hurt to give it a try.
