What size exhasut pipes?
Old Jan 18, 2012 | 09:41 PM
85LSburb's Avatar
Default What size exhasut pipes?
I have a lq4 with duel plane carb intake, FAST ez efi, smaller cam in it. I have factory manifolds now but i am about to order headers. What size pipes would be best 2.5s or 3 inch. Both will be duels. Both will be made buy local shop if it matters. thanks
Old Jan 18, 2012 | 09:50 PM
butler's Avatar
I ran 3" and no loss in power.
Old Jan 18, 2012 | 09:51 PM
bwkmaro's Avatar
are you gunna go further with the motor? id say dual 2.5 if not that will be enough flow
Old Jan 19, 2012 | 01:00 AM
VandykeT/A's Avatar
Use 3 inch. Leave yourself room to grow.
Old Jan 19, 2012 | 02:02 AM
bww3588's Avatar
Also a good cross over.
Old Jan 19, 2012 | 05:24 PM
85LSburb's Avatar
I will use a h pipe unless the exhaust builder can do a x. Is there any gains between h and x. I do plan to upgrade the heads one day then maybe a 421 short block long time from now.
