LS6, FAST 90,92 or 102???
Old Jan 23, 2012 | 01:24 AM
Blk98Vert's Avatar
Yeah it lost 2 or 3 if I remember correctly on the engine dyno. You will never feel that. Also GM High tech now doesnt use anything else nor does hot rod. Neither does high performance pontiac. And no you arent because the cam and heads determine powerband. If the heads dont flow more the powerband will remain the same, it will not shift up or down. The better intake will improve airflow at different rpms and make more power but it wont move
Old Jan 23, 2012 | 01:35 AM
wildcamaro's Avatar
Oh ok I get what your saying...Yea I guess I meant to say under curve power not power band, I sound like im talking like its a 2stroke dirtbike or something lol
Old Jan 23, 2012 | 01:37 AM
Blk98Vert's Avatar
Right. But like I said the losses down low are minimal, you will never feel 3hp at 3000 rpm when you are gaining 10 everywhere else
Old Jan 23, 2012 | 01:48 AM
lemons12's Avatar
Originally Posted by wildcamaro
But see when you say the 102 will gain over the 90 (which is true when it comes to peak power) but you leave out the fact that at minimum the power shifts in the rpm range...I have seen countless tests where a 102 replaces an LS6 and it loses tq in the lower rom range, and while I don't have an experience with the *** dyno I'm not lying either...search Gmhightechperformance and hot rod ls1 cam tests and you will see what I'm describing...(and don't give me the magazine conspiracy theorist comment bc that's a whole other conversation in itself)
A 102 MIGHT lose a couple below 3500 RPMs.... Only time I'm at 3500 RPMs is when I'm leaving a red light and trying to beat grandma in her mini van.
And like stated, if you are gaining 10+Rwhp everywhere else, nice tradeoff.
Old Jan 23, 2012 | 01:55 AM
03EBZ06's Avatar
thats a good point. My car never sees south of 5500 at the track.
Old Jan 23, 2012 | 02:07 AM
Mighty Whitey's Avatar
Wanna sell the busted fast 90? Specifically the top shell?
Old Jan 23, 2012 | 05:34 AM
RyanEricW's Avatar
busted parts ftl
Old Jan 23, 2012 | 10:41 AM
Originally Posted by RyanEricW
busted parts ftl
True story. I've got one that needs some MAJOR work.
Old Jan 23, 2012 | 11:00 AM
wildcamaro's Avatar
I know u will never feel that low end 3 hp/tq...I was just trying to point out that there are different dynamics with the bigger intake...good discussion though
Old Jan 23, 2012 | 12:41 PM
R6cowboy's Avatar
416c.i., Fast102 FTW
Old Jan 23, 2012 | 04:16 PM
jlcustomz's Avatar
[QUOTE=03EBZ06;15871697]Recently cracked my lower end on the FAST90. I have to get a new intake, but at this point, I am very skeptical about the 102.
How much power is the 102 worth over a 90, if any?? web links?
I may have to fix my 90 somehow. Are there other options out there?
See engine in sig.[/QUOTE
Ive done plastic welding using from a solder gun to my current lcd controlled hot air gun from urethane supply co. You need identical material to plastic weld. Also plastic welds need to be thicker on one side because the plastic doesn,t cross link molecularly as when it's first formed. On thermoplastics , you have to be careful of warping . It is possible though, but what do I know about plastic welding.
Old Jan 23, 2012 | 06:23 PM
  #32
03EBZ06's Avatar
Should have the 102 on this week and test drive it by Sat. A new intake and another 50 to 100hp of nitrous should make things interesting.
Old Jan 23, 2012 | 07:22 PM
  #33
hardcore4sure's Avatar
I got a busted one, I'll want to get rid of.
Old Jan 23, 2012 | 10:59 PM
  #34
03EBZ06's Avatar
I appreciate the inquiries coming in on the FAST 90, but note I sold it about an hour ago. It was a good intake!!
Old Jan 25, 2012 | 06:00 AM
  #35
ls11998's Avatar
I have 92mm I love it
Old Jan 25, 2012 | 08:34 AM
  #36
thunderstruck507's Avatar
Originally Posted by Blk98Vert
Again we arent being uptight just preventing the spread of bad info.
The bullshit meter on tech has been pegged lately. Lots of bad info being posted and worse REPEATED.
Old Jan 25, 2012 | 08:38 AM
  #37
Blk98Vert's Avatar
Should have seen the FAST thread in the newbie section. 10 replies that the LS6 didn't lose anything under 450 rwhp or you had big heads and a cam. Even though GMHTP gained double digit numbers on a 460fwhp LS1 with bolt ons and a 224/230 cam
Old Jan 25, 2012 | 08:50 AM
  #38
Yeah I was posting in there too. At some point though it gets old repeating myself over and over to people who think one example trumps the dozens that contradict it.
