Help Assembling Engine, LS6 Build, First Timer.
Cam position
Crank position
Knock sensors
TPS
Coolant temp.
Primary o2 sensors are next on the list. I won't be running secondaries.
First question is, what goes in the hole on the opposite corner from the temp sensor?
I'll probably use this thread in the future as questions pop up.
Current state of engine and car.
Next items up are the fuel injectors. What lb per hour rating should I be looking for?
Engine has the following.
MS3 cam
1 7/8 long tubes
243 Heads with 5 angle valve job
and the above mentioned FAST 92 w/92mm TB
What type of fuel system/pressure are you going to be running?
You can put a coolant temp sensor from a 96 and up M3 in that hole and your in dash coolant temp gauge will work (at least it will work as BMW intended which is debatable as the stock gauge has a buffer in it).
The sending unit just scews in, no adaptor is needed! Damn handy...
I'm sticking a LS6 into a 98 M3 as well....
