Header Studs
Old Jan 31, 2012 | 02:51 PM
splitfinger09's Avatar
Default Header Studs
I am installing header studs and want some opinions on what to put on the threads. I am thinking anti sieze on the threads that go into the head and possibly thread locker on the nut?? What do you guys think? Also does anyone know if its a lock nut? Thanks for the help.
Old Jan 31, 2012 | 02:57 PM
tim99ws6's Avatar
Are you talking about the ARP header studs? if so, a little anti-sieze wont hurt it. I just run the stud down until they bottom out finger tight, then back 1/8 turn. Then slap on the header, then washer, then nut. I never used anything on the nut side, but do double check them after a week of driving. Some will have loosened up a touch.
http://www.google.com/products/catal...=0CCUQ8wIwAg#p
Old Jan 31, 2012 | 03:06 PM
Yep ARP header studs. How do you like them? I think they will be much better than bolts. After you heat cycle did you have any problems with them staying tight?
Old Jan 31, 2012 | 03:09 PM
tim99ws6's Avatar
They are awesome in my setup. I use them in a turbo app and they seal down nicely. Other added benefit is you can hang the header/manifold or gasket on the studs and then worry about getting the nuts for them so that's nice too. They are spendy though!
I never really had any problem staying tight, but mine isnt a DD.
sepsis's Avatar
I was thinking of using studs too, but I think I'll stick with bolts and lock tabs. I think the thread locker won't help much with the heat going on in that area. Might want to try lock tabs.
I can't seem to find lock tabs for the header bolts though.
Old Jan 31, 2012 | 03:11 PM
I like the idea of studs simply because it protects those threads inside of the head. Also it makes the install a bit easier. For the $100 price tag though they are not cheap...
Old Feb 1, 2012 | 08:56 PM
Header studs ftw!
Make sure you use ARP torque lube or anti sieze. Tourqe to 26 ft lb.
