help needed to restore procharged car back to N/A
The bolts on top and the bottom ( that go through the Alt. ) are 125MM long. The one that goes into the block @ 9 o'clock is 90MM long. The one for the Idler is 45MM long.
I know these are the original bolts that came with the bracket as I put nuts on the ends so I would not loose em.
You might have to try a bolt specialty store to find the bolts. I boought some 150MM bolts online when I relocated the Idler for the FAST on my truck.
