Removing power steering pump???????
Old Mar 19, 2004 | 09:29 PM
niksmoov's Avatar
Default Removing power steering pump???????
I want to remove my power steering pump which is not a problem but I need to know does something like a pulley goes in its place. In other words once I take it off do I just buy a shorter belt or another delete pulley like the one for the A/C?
I need some help!!!!!!!
Old Mar 21, 2004 | 02:37 PM
WILWAXU's Avatar
Most just run a different (shorter) belt. BTW.. the A/C runs it's on belt..
Old Mar 24, 2004 | 08:09 PM
Magyver's Avatar
Hey can you tell me how to remove the power steering pump? I have a leak somewhere coming from the pump.
Old Mar 25, 2004 | 08:05 PM
WILWAXU's Avatar
There are 2 13mm bolts behind the pulley that hold the pump to the head braket. With a gear wrench they come out in ~5mins.
Or you can pull the pulley off..
Old Mar 25, 2004 | 08:08 PM
Scalpel's Avatar
They're 15MM bolts
