LSX throttle bodies
Old Feb 20, 2012 | 02:30 PM
Hardcoresoldier's Avatar
Default LSX throttle bodies
I am going to be putting a FAST 102 on the 402 LS2 in my C5. I have been looking at the available throttle bodies, and am just not sure which to go with. I am currently looking at these:
TPiS 90mm 1500cfm http://tpis.com/parts/view/53
TPiS 102mm 1800cfm http://tpis.com/parts/view/260
GM LS2
NW 102mm LS1 or LS2 style
Engine specs: 402 LS2, 11:1 compression, LG G5X3 cam, triangle casting LS6 heads (will eventually be upgraded to TFS heads) .
Or is there a different one I should be looking at?
Old Feb 20, 2012 | 02:54 PM
Blk98Vert's Avatar
Either one of the 102s would be good, they are good brands
Old Feb 20, 2012 | 02:59 PM
splitfinger09's Avatar
Are all 102's created equal? I mean like why would one buy the fast over the NW?
Old Feb 20, 2012 | 03:10 PM
well, according to their website, the FAST 102's are all cable driven, I need DBW.
Old Feb 20, 2012 | 03:17 PM
99Bluz28's Avatar
IMO, you can't go wrong with the NW TB's, and you can get a NW 96TB for a good amount less than NW 102TB.
Old Feb 20, 2012 | 04:15 PM
OP would you mind explaining the diff between cable driven and DBW?
Old Feb 20, 2012 | 04:30 PM
Camaro/Firebird throttle bodies have a traditional throttle cable, like on every TPI/TBI/carb engine.
Corvettes (not sure about GTO's) are Drive By Wire. They have a sensor on the gas pedal that sends a signal to an electric motor on the throttle body that in turns opens the throttle blade to what ever % the gas pedal is pushed down.
