LS1 intake for boost?
Old Mar 8, 2012 | 02:46 PM
bugy's Avatar
Question LS1 intake for boost?
im planning to use my LS1 intake into my 6.0L turbed setup, im wondering if it will work good with boost from turbo, it will be boosting something like 12 psi, what do you think, will intake work good with that boost? thanks
Old Mar 8, 2012 | 05:28 PM
conan's Avatar
Good for what ? It will work just fine as far as its strength, It just doesn't flow as well as other intake manifolds.
Old Mar 8, 2012 | 05:53 PM
NemeSS's Avatar
Its good enuff, but may need a bolt down plug like the ebay ones.
Not the auto parts rubber ones. I use metal 1 3/8 freeze plugs. But it may blow out.
It works fine for n/a or egr delete
Old Mar 8, 2012 | 07:25 PM
bugy's Avatar
well that was my bad for not mentioning good for what, will it take the boost? or it may break off or something!! about flow rate, which one flows better than this? cause i got this from my camaro if there are more considerably gains i could get it. thanks guys
Old Mar 8, 2012 | 10:48 PM
conan's Avatar
If you can find a cheap ls6 intake that would be the best bang for the buck and you wouldn't have to deal with plugging the EGR hole (as nemeSS mentioned) on the ls1 intake. The ls6 also flows better than the ls1.
Old Mar 9, 2012 | 01:49 AM
bugy's Avatar
thank you guys, im looking for a LS6 intake then, in case i dont get it, will Ls1 intake be proper to handle those psi?
Old Mar 9, 2012 | 02:39 AM
xxrillixx's Avatar
yes. ls1 will handle it, just wont flow as well.
Old Mar 9, 2012 | 03:20 AM
ls1 1990 VN's Avatar
Why don't you just do some research first....like, hit the search button.
Old Mar 9, 2012 | 10:13 PM
bugy's Avatar
thanks already found a cheap LS6 intake, im going with it!
