HELP! Cant get motor mount bolt out!
Old Mar 15, 2012 | 11:06 PM
Ws6power1's Avatar
Angry HELP! Cant get motor mount bolt out!
I need some ideas guys. I'm doing a poly motor mount swap. Everything was going fine until I hit the last bolt holding the clamshell to the motor on the drivers side. The 4 on the passenger side were not problem, first 3 on the drivers side not problem, last bolt will not come out. I have sprayed it with pb blaster several times and let it soak in over night. Hit it with a mini torch to try to heat it up nothing. I've pulled on my kobalt ratching wrench so hard I can feel it bending nothing. Now the head is half way stripped and I don't know what the hell to do. I'm almost ready to break my drimmel out, cut it off and try to drill it out the bolt and use a bolt / screw remover. Please help this is holding up my install. Thanks
Old Mar 15, 2012 | 11:12 PM
97badass's Avatar
Get a 6 point socket and a long breaker bar. Or an impact gun with a 6 point socket
Old Mar 15, 2012 | 11:28 PM
Ws6power1's Avatar
I was thinking about an impact i just don't think theres room to get in there. Same thing with the breaker bar. I will go pick up a 6 point socket though. Mine are the star shaped ones.
Old Mar 16, 2012 | 12:21 AM
97badass's Avatar
Yeah a 12 point is bad on stuck bolts. Just get the correct size 6 point and a breaker bar.
Old Mar 16, 2012 | 12:35 AM
Ws6power1's Avatar
Got it with a 6used point thanks guys.
