fouled plugs on driver side
i've been told o2 sensors, bad rings, and header gasket leak so far......any other suggestions
Did you check the voltage on the injectors? Check the coil packs?
Header gaskets would never prevent a car from starting.
Did you work on the car recently? Maybe pop a vacuum line off? Any SES lights??
