tuneing after LT and intake swap?
Old Mar 23, 2004 | 05:46 PM
flexybronc's Avatar
Default tuneing after LT and intake swap?
Im planning on doing jet hot LT's and their catted Y. Plus installing a LS6 intake. I have a lid on it grannitelli maf, ls1 motor sport lid and a loudmouth do you guys think i should have the car tuned. Not worried about check engine lights being on just looking for most power and drivability. It will probably be a good 6 months before i buy a cam or anything for it. thanks
Old Mar 23, 2004 | 06:38 PM
M6HuggerSS's Avatar
find out what your AFR is by dynoing the car and that will tell you if you need a tune!
Old Mar 23, 2004 | 07:32 PM
Griswold's Avatar
You probably gain some power because of the maf and longtubes richening or leaning out the mixture. IMO, a tune isn't really worth it until you go internals unless you can afford it or are trying to set some kind of record. I would wait until you get a cam
Old Mar 23, 2004 | 09:52 PM
Gr8WhtLS1's Avatar
Go with a tune ! A good tune from someone like MTI cost 500 initially then its free for two weeks then from then on its 75 and alot of peopl see a tenth to a tenth and a half with a tune from MTIplus they delete codes if you decide to remove any emissions equipment and if your an A4 youll get even better results.
Old Mar 24, 2004 | 07:43 PM
flexybronc's Avatar
thanks for the info guys
Old Mar 25, 2004 | 12:34 AM
16nrollininaws6's Avatar
If you have the money, get a tune. You could pick up an extra 10 rwhp or so!
Old Mar 25, 2004 | 12:59 AM
JimmyY2KWS6's Avatar
I would get a tune. I just did the same mods and will be tunning my car in the next couple of days.
Jimmy
