T56 rubbing when downshift to 2nd and also 1st while idling
Old Mar 25, 2012 | 04:08 AM
DerekH85's Avatar
Default T56 rubbing when downshift to 2nd and also 1st while idling
I have a 98 SS mostly stock few mods. I recently had the Starter output housing break off into the bellhousing and one mounting tab also broke. While i had everything tore down i rebuilt the tranny with a stage 2 rebuild from thegeargox and installed a Spec clutch kit, new slave, and new flywheel. Now while the car is sitting and idling its grinds goin into first if i try to put it in gear immediatly after pressing clutch , if i hold the clutch down for a few sec it goes in fine. Same when im downshifting into 2nd. Is this because the clutch is not engaging fully and sticking to the flywheel or pressure plate? Maybe shim needed? Need some help, other than this problem the T56 shifts great!
Old Mar 25, 2012 | 04:42 AM
davidws6's Avatar
Maybe there's still air in the hydraulics ?
Old Mar 25, 2012 | 04:46 AM
DerekH85's Avatar
Ive Bled numerous times, even with a MityVac got a lil air.. def no more air in the system.
Old Mar 25, 2012 | 12:01 PM
gMAG's Avatar
You might try placing this question in the Transmission section below.
