Ignition and plugs....
Also Im not sure what the v-power plug is.
I just ordered some NGK Iridiums (pre-gapped .050) and GM performance plug wires to replace a set of Accel 9000's I was using, I had one touch the header and it burned it pretty good.
you want a wire wound core, and when you get the wires check the ohms
it should read between 25 and 150 ohms per foot, (ex. a 116 ohm plug wire that is about three feet long works out to about 40 ohms per foot) any less than 25,or more than 150 is not very good for performance.
the msd wires should read about 40 ohms per foot.
