Oil Pressure Sender
Far Left
97-2000 Corvette OFAC (still available) Part Number 12551587
Comes already drilled and with a metric thread M12 x 1.5
Drill out the metric thread using a 7/16" drill
Tap 1/4 pipe thread
Use a 1/4" male x 1/8" female reducing bush
Screw the 1/8" pipe threaded sender into that.
Center
Fbody OFAC (No Longer available from GM new**) Part Number 12551595
Comes blank (not drilled and no thread)
Drill out the boss using a 21/64" drill
Tap 1/8 pipe thread
**Part superceded by 12577903
Right
GTO OFAC Part Number 12577903
Drill the center using a 21/64" drill
Tap 1/8 pipe thread
Screw in a 90 deg 1/8 pipe male female elbow
