Motor mount bolt size
Old Apr 22, 2012 | 11:23 PM
bigantws6's Avatar
Default Motor mount bolt size
I been searching for the motor mount bolt but the only one I find is the one that goes into the block I need the one that goes threw the motor mount
Old Apr 23, 2012 | 07:05 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
This is prob no help, but I do know they are 18mm bolts. I don't think length matters, as long as they protrude PAST the clamshell. width is a different story, and I haven't been able to find that answer either.
Engine Mount Stud-to-Engine Block - 37 lb ft
Engine Mount Through Bolts - 70 lb ft
Engine Mount Through Bolt Nuts - 59 lb ft
Engine Mount-to-Engine Block Bolts - 37 lb ft
Old Apr 23, 2012 | 07:26 AM
bigantws6's Avatar
Yea me either maybe ill call the dealership see I'f they know the size and if they do ill let u know
Old Apr 23, 2012 | 07:28 AM
bigantws6's Avatar
See I lost the dam nut that goes on it and my dumb azz put the bolt in already so if the dealer doesn't know ima pull one out and go find one at lowes
Old Apr 23, 2012 | 05:25 PM
bigantws6's Avatar
The bolt size is 12x1.75x160
Old Aug 30, 2013 | 08:40 PM
54inches's Avatar
Are the ones that go INTO the block 10x1.5?
