removal of PS and AC - wot pulley set up ?
hi all
i dont need the A/C and P/S, does any one know of a pulley set up or belt set up that can be used, my alt sits just at the side of the oil pan, if so can you send me links, i live in uk so its real hard to find parts for ls engines
ideally i would like to run the water pump and alt of the crank damper with as little pulleys as possible
many thanks
Finlay
many thanks
Finlay
From: Your girl's back door giving her the long stroke while you're at work
