Reuse stock muffler to create sleeper?
Old Mar 27, 2004 | 01:36 AM
Z28Venom's Avatar
Wink Reuse stock muffler to create sleeper?
I have a question for you guys... Have any of you done exhaust work and then reused your stock muffler to create a sleeper?
Pacesetter LT's/3" ORY/3" I-Pipe.. Stock 2000 Z28 Muffler... I was thinking of this setup. Because once the cam is in.. I'd like it to be a sleeper. Only hear the cam when I open the cutouts?
What do you guys think? Would I be choking off the headers and ory?
Thanks
Old Mar 27, 2004 | 03:27 AM
14u2nv's Avatar
There are several board members on this forum that run headers, ORY, and the stock catback. Nineball(Tony)had headers, no cats and a SLP Dual Dual exhaust. He ran this set-up even on his 434 stroker. The Dual Dual is one of the highest flowing catbacks available and is relatively quiet too. You can buy a used one for like $200 or less.
Old Mar 27, 2004 | 05:00 AM
TruBloodTransAm's Avatar
that's what i'm running right now, Pacesetter LT's, Pacesetter ORY, stock exhaust+3"cutout right before the muffler, i usually leave my cutout open, sounds pretty good (although i still have to cure my rasp), and when my cutout is capped it sounds real close to stock...i'm still thinking about moving up to a WS6/SS exhaust+cutout or something, i figure i could get a bit more hp out of it and still cap it to sound stock...
Old Mar 27, 2004 | 11:30 AM
Z28Venom's Avatar
Thanks for the responses.. How would a muffler shop go about adding the stock muffler to a 3" exhaust system?
Thanks
Old Mar 27, 2004 | 05:28 PM
SStroked 410's Avatar
They could use some reducers and then back to 3"
I was looking for the same set up
kooks 1 7/8" headers QTP y-pipe into a stock catback but with my set up I would need 2 different tunes so I said forget it and got a slp d/d
Old Mar 27, 2004 | 08:10 PM
BlueSS's Avatar
i have a stock ss muffler sittin in my garage if ur interested...
make an offer it's only taking up space...
Old Mar 28, 2004 | 08:32 PM
cm02WS6's Avatar
I'm still running my stock WS6 catback with LTs and 3" catted Y. I'll probably dyno it Saturday, so we'll see what it does. I figured if anything I would swap the muffler out for a Magnaflow if the numbers are low.
