LS1 header gasket questions...
Old Apr 27, 2012 | 10:06 AM
92slomaro's Avatar
Question LS1 header gasket questions...
I am putting my 02 z28 back together after a awesome ls7 lifter failure. And was just wondering what kind of gaskets every one was using. The header gaskets i got, when i first put the car together, were junk and i got about a year out of them before they cracked. I then put factory manifold gaskets in and they seemed to be ok for a while. Now that the car is apart and going back together i was just wondering what kind of gaskets were the "better" ones? Any input would be great!!!! Thanks!
Old Apr 27, 2012 | 10:19 AM
LS-ONE_DAY's Avatar
GM MLS gaskets.
http://www.ws6project.com/user_stor/...ets-set-of-2-/
Old Apr 27, 2012 | 11:34 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Originally Posted by LS-ONE_DAY
GM MLS gaskets.
Old Apr 27, 2012 | 12:44 PM
boostit5.3's Avatar
Old Apr 27, 2012 | 12:57 PM
derrickman05's Avatar
That's what I went with
Old May 11, 2012 | 09:23 PM
92slomaro's Avatar
Thanks guys fo the answers!!! That seems to be what im going to go with.
Old May 11, 2012 | 11:53 PM
slammedc5's Avatar
Same here. I coat mine with copper gasket spray. Gives a awesome seal
Old May 12, 2012 | 09:47 AM
dans94z28's Avatar
same +1 ^^^^
 Michael S. Palmer
Old May 12, 2012 | 03:43 PM
M6transam's Avatar
I just installed MLS gaskets..One side leaks and I can't seem to get it to seal.
Old May 12, 2012 | 04:42 PM
JRENIGAR's Avatar
Factory 197,000 mile gaskets here and not one problem, hmmm...
Old May 13, 2012 | 11:15 AM
AmarilloWS6's Avatar
I re used my factory ones and haven't had any problems. I'd go with the factory steel gaskets.
Old May 14, 2012 | 06:49 PM
GMtechmatt's Avatar
factory gaskets !
Old May 14, 2012 | 07:46 PM
VandykeT/A's Avatar
I'm still running the stock 79k mile gaskets that came on my T/A. They've been through 2 different sets of headers. My camaro had papers ones on it and after I took it apart and replaced it with carquest mls gaskets it wouldn't seal. I ended up having to flat file my headers and I used the Percys with the fuzzy stuff on them. The MLS probably would have worked after filing them but the percys ones are good as well.
Old May 14, 2012 | 07:50 PM
Blownbayou's Avatar
Just put bbk lt on mine and had a choice..... Graphite paper bbk gasket or the stock metal gaskets. My stockers were in great shape so the stockers stayed on
Old May 14, 2012 | 08:10 PM
ls1sickandtwisted's Avatar
Stick with the factory steel ones when I got my hooker it came with the paper ones but I like my stock ones I just filed my headers so they get be smooth and used the stock gaskets
