solid motor mounts
Also as far as lining them up to install them, I just did 1 side at a time and they gave me no trouble at all.......It did kinda suck with the headers on the car but every motor mount will
As for holes, our mounts are machined to the exact dimensions as the factory mounts, the hole pattern is the same and the height is also the same. The issue we did have is we engraved the word "UP" on the wrong side of a batch of mounts. This caused the customer to attempt to install them upside down. We quickly corrected this.
I hope that helps,
Ryan
^^this
I sold my old stands to a guy on here who swapped his in out side of the car on my old ones so he could just take the old ones out and put the new ones right in.
I did my solids with the engine in and the accessories off because they were already off at the time.
The mounts I received were indeed part of the defective batch, the top of the mount should be the the side that is further away from hole where the motor mount bolt slides in. Double check this and don't install the first time with loctite without double checking to make sure it is the right direction.
