2002 LQ4 Camshaft?
Old May 3, 2012 | 10:51 AM
davidc212k's Avatar
Default 2002 LQ4 Camshaft?
planning on doing an LQ4 camshaft swap.
i know that the LQ4 is an LS based engine.
just wondering what kind of camshaft can be installed on the LQ4.
Can an LS1 camshaft be installed? etc.
What camshaft recommendations.
I want it loud and good idling.
Thanks.
Old May 3, 2012 | 05:28 PM
93camaro_zzz's Avatar
Yeah it still has the same camshaft bore specs and stuff. You can fit an LS1 camshaft in there. If you want it loud a good Idling, I would look at a camchaft around 224 duration, and stay at 114LSA and above. Maybe even check out a stock Z06 cam, I know alot of people use those.
Old May 3, 2012 | 06:55 PM
thegroup's Avatar
Thought the 02 Ls cam was a lq cam?
Old May 3, 2012 | 11:03 PM
davidc212k's Avatar
most of the camshafts say that 1.8 rockers not recommended. reason i state this is because i want to use stock lq4 rockers etc. i only want to get the camshaft.
with that said which cam can be used with stock rocker arms.
What kind of rockers does the 2002 LQ4 have?
its an all stock 2002 LQ4 Engine.
Old May 3, 2012 | 11:09 PM
davidc212k's Avatar
i think i found the answer to my own question, lol
seems like the LS1 and LQ4 have an 1.7:1 rocker ratio.
I am thinking about buying this camshat.
99-TR-TORQ-L5
Thunder Racing Custom Camshaft
"TR TRuTorq" Level 5 - 227/239 .614/.621 115 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Good bottom end and mid-range torque. Requires computer tuning. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
since it states the following - the use of 1.8 rockers is not recommended.
I am new to this engines stuff. i guess i have to get different Rocker Arms? Since i have a 1.7 ratio?
Old May 4, 2012 | 03:23 PM
Redbull87's Avatar
Im not sure you want to go with a cam with that much lift on stock springs and rockers.I believe being under .600 is a safe bet but dont quote me on that.
My tsp 228r cam on my lq4 is a great daily driver cam and has a nice lope at 800rpm idle.Mid range and topend is stout.I suggest using a good spring and hardened pushrods regardless what cam you decided for cheap insurance on the valvetrain.
Old Oct 4, 2012 | 03:06 PM
LQ4-E39's Avatar
Resurrecting this thread.
Obviously the stock LQ4 springs are not suitable for use with an aggressive aftermarket cam like the 227/239 .614/.621 the OP is hoping to use.
However, what about using the stock LQ4 springs on a stock 2005 LS2 cam?
Specs are 204/211 .525 lift 116.5 lsa for the LS2 cam.
Can the LQ4 springs handle that lift?
