LS6 Intake question
Old May 7, 2012 | 12:53 PM
ls1sickandtwisted's Avatar
Default LS6 Intake question
So I decided to stick with a ported LS6 intake for now thanks for all the advice the fast 102 is to much for my cubes at this point I currently have ported LS1 throttle body my question is how big can I go on the LS6 intake or its the same if I keep my ported LS1 TB
Old May 7, 2012 | 03:04 PM
jrob56's Avatar
I dont know for sure what you are asking, but I think you are asking if the ls1 throttle body has the same opening as the ls6 intake? If that is your question then yes, they both are a 78mm opening. Just keep your ported stock ls1 TB.
There are some 80mm ones out there like BBK for instance, but its a waste of money. Ported stocker is pretty much as good as it gets with the ls6 intake.
Old May 7, 2012 | 04:11 PM
Yea that was my question but thanks if my stock ported TB wrks fine and if I dnt have to ipgrade for a bigger then I'm sticking with it I had more neg and positvies on aluminum intakes so I decided to get a fast 102 but then again its to big for my cubes 5.7 not until I switch to bigger cubes like 6.0 then I would get it but for now the ported ls6 should be great and if u say the stock ported TB is good enough then that answers my question I mite do a little big Injectors but maybe lol
Old May 7, 2012 | 04:20 PM
jrob56's Avatar
Cant change injectors unless you plan on getting tuned, what year is your car. Stock injectors should be fine for any bolt on car. Especially if you have a 98, or 01-02 with the 28lb/hr ones.
Old May 7, 2012 | 04:33 PM
Yea I do plan to get it tune since I'm deleting cats and 02 sensors so I need a tune I got a orgrammer for now for the dual intake and headers once I change gears stall intake underdrive pulley x pipe and light flywheel I will get a tune here at a shop in twn
