Car Won't Start
Old May 12, 2012 | 07:00 PM
02streetsweeperSS's Avatar
Default Car Won't Start
A little background information on the car: It is a H/C/I car with most bolt-ons.
About three weeks ago, I washed my engine bay before a car show. After the show my car took about three attempts of starting to get it to fire. From then on it took more and more attempts to get it to fire. The starter will turn the motor over, but it will not fire.
To remedy the problem I have installed new spark plugs, plug wires, cam sensor and crank sensor. I have also checked every connection and fuse. Nothing seems to be out of the norm. I scanned the car, but it is not throwing any codes.
Any input would be greatly appreciated.
Old May 12, 2012 | 07:13 PM
conan's Avatar
Have you checked for fuel pressure ?
Old May 12, 2012 | 07:15 PM
Tyrel2018's Avatar
have you checked all the basics of fuel, air, spark? i figure you have air, most likly fuel, but spark is the big one and the one that can help identify what might be going on
Old May 12, 2012 | 08:03 PM
I have not checked for fuel pressure, but I do have fuel in the rails.
I do not know how to check the coil packs for power.
Old May 12, 2012 | 08:23 PM
US_Army_Z28's Avatar
Any way to post a video of what exactly the car is doing when you try to start it
Old May 12, 2012 | 08:45 PM
I will try to post up a video tomorrow.
Old May 12, 2012 | 09:10 PM
RacerXLs1's Avatar
Coils?
Old May 12, 2012 | 09:37 PM
Unfortunately, I do not know how to check them.
Old May 13, 2012 | 09:30 PM
conan's Avatar
Get a piece of wire and strip 2'' of the insulation off one side, and get a alligator on the other side. Take the striped side and rap it around any spark plug you may have laying around. Pull one of your plug wires off and plug it in to the random plug. Ground the alligator clip to the engine and have some one crank the engine while you watch the plug for spark.
Old May 14, 2012 | 08:27 PM
It is raining here, so I have not been able to get a video yet. Will I have to re-tune my car if I reset my PCM?
Old May 14, 2012 | 08:31 PM
I can understand that its been raining for 2 days straight hhere and what do you mean by resset your pcm?
Old May 15, 2012 | 12:30 AM
Take the positive and negative ends that connect to the battery, disconnect them, and touch them together for a minute.
Old May 15, 2012 | 01:16 AM
Thats what i figured ive never had an instance where dooing that erased a tune it generally just resets codes. Not saying its impossible to happen ive just never had it happen to me
