Tex speed y
Old May 15, 2012 | 08:05 PM
dans94z28's Avatar
Default Tex speed y
I have installed my hooker long tubes, tsp ory and mangaflow catback. Question is does the tsp not work with the spoon mid mount torque arm? Or is something not install right? My y pipe hangs way to low to even clear the cross member and the merge is well past the sing dip in the cross member as well.
Old May 16, 2012 | 10:23 AM
streetknight2's Avatar
Do you happen to have any pics? I have the same torque arm and was fixing to order the same Y.
Old May 16, 2012 | 01:40 PM
dans94z28's Avatar
I will when i get home today
Old May 16, 2012 | 08:02 PM
dans94z28's Avatar
spohn* hope the pictures help.
Attached Thumbnails Tex speed y-imag0576.jpg   Tex speed y-imag0577.jpg   Tex speed y-imag0578.jpg   Tex speed y-imag0581.jpg   Tex speed y-imag0582.jpg
Old May 16, 2012 | 08:04 PM
dans94z28's Avatar
a few more
Old May 16, 2012 | 08:07 PM
dans94z28's Avatar
you can see in picture 3 where the mounts are and where the y meets past it and how low it sits compared to the frame mount for the tunnel brace
Old May 16, 2012 | 08:10 PM
mikh338's Avatar
my buddy runs the exact same setup with no issues
Old May 16, 2012 | 08:16 PM
dans94z28's Avatar
does he have a spohn mid mount torque arm? or just no clearance issues?
 Michael S. Palmer
Old May 17, 2012 | 08:00 AM
My current exhaust with the Spohn torque arm the Y runs between the tunnel brace and the floor pan, not under it like yours appears to. However, mine is reduced down to 2 1/2" right there and still hits the tunnel brace. I read on Spohn's site that you have to have a tunnel brace made for LT's to get the exhaust through properly. BUT, my car is lowered and they say the tunnel brace for LT's will cause ground clearance issues on a lowered car.
Sounds like one of those "damned if you do, damned if you don't" deals to me.
Let me know if you get it worked out.
Old May 17, 2012 | 02:00 PM
mikh338's Avatar
yes he has the exact same setup for everyting and i do pretty much to but i have a pacestter y pipe with no issues with my spohn tunnel mount t\a.
Old May 17, 2012 | 02:38 PM
dans94z28's Avatar
pacesetter y is very different and clears w/o any issues. its the tsp y thats made different
Old May 23, 2012 | 09:24 PM
dans94z28's Avatar
So tomorrow I will be back under the car with it on a lift this time and see if I can get some ground clearance and the tq arm to mount up. After looking at a pacesetter y on another car it swoops upward at the y and why it has more clearance than the tsp y. But we will see tomorrow. Mor Picts to come.
