Quick Help about a test
I removed the rail, with the injectors. Then, with the rail still hooked up to the fuel line, and cheap, plastic cups under each injector, I powered up the pump with a turn of the ign key. Verify that you have full 58lbs pressure.
From here, it's just observation. Check to see if any of the injectors spill fuel.
Btw, gasoline will melt the plastic cup, given enough time!
Further, you can hook up a 9v battery to each injector, in turn, to operate the inj.
Fuel will spill out the inj, into the cup. After opening/releasing the 9v, wipe any fuel clean. Then observe for leakage.
Please be careful. The 9v can create a spark. For this reason, I use at least 3 feet of wire between the 9v battery, and any injector, or fuel.
Also, to AVOID EXPLOSION, the opening & closing of the 9v circuit SHOULD ALWAYS be done at the 9v battery...NOT at the injector.
