power steering pumps
Old May 30, 2012 | 08:38 PM
asinapple8805's Avatar
Default power steering pumps
Hi,
I bought a used LS6 from someone and it came with a f-body front accessory drive setup. The only problem is that the seller didn't include the power steering pump, but did include the brackets.
I'm looking for a power steering pump both in the local junk yards and online.
what power steering pumps are compatible?
f-body v6?
corvette?
truck pumps?
also if i were to purchase one online, where do you recommend that i find a cheap used or rebuilt one. I just need to get this swap car on the road ASAP.
thanks in advance
Old May 30, 2012 | 09:06 PM
usafws6's Avatar
pretty sure your stuck with a ls1 fbody pump as your only option.
Old May 31, 2012 | 07:21 AM
03Sssnake's Avatar
If you have the budget, TurnOne makes the best steering pumps for these cars. TurnOne will re-build the stock ones for about half the price of their new unit.
http://www.turnone-steering.com/ls1-pump/
Old Jun 1, 2012 | 03:24 PM
thanks for the help guys. I was really looking into the turn one pumps, but that price makes me cringe a little. how is the pulley held onto the pump shaft?
Old Jun 1, 2012 | 07:39 PM
sjsingle1's Avatar
stock pulleys are press fit...........turn one adds a safety wired bolt
Old Jul 4, 2012 | 12:57 PM
MrH00nel2's Avatar
do you need a bench press to put the stock pulley back on? and how much tq?
Old Jul 4, 2012 | 03:50 PM
sjsingle1's Avatar
you can use a puller tool......auto zone has it for a rental......it installs too
