sold motor mounts with solid transmission mount?
Old May 31, 2012 | 01:03 PM
3rdCoastPowerSports's Avatar
Default sold motor mounts with solid transmission mount?
i have a C5 corvette M6. I have solid motor mounts. Im wanting to replace the transmission mount. I found both oem mount and a solid trans mount for roughly the same price. would you recommend the solid trans mount or the oem trans mount for use with my solid motor mounts? thanks
Old May 31, 2012 | 02:28 PM
The_Bishop's Avatar
I don't think I'd use a solid trans mount ever in anything. From what I've seen, it leads to broken parts, like tailshaft housings.
Old May 31, 2012 | 08:53 PM
sabersaw30's Avatar
Yeah you need some give somewhere are something is breaking.I run solid motor mounts to I was wondering on the poly trans mounts but I have heard bad vibration when you put these on.
Old Jun 1, 2012 | 12:23 PM
armyboyatc's Avatar
Run the solid motor mounts with a poly trans mount. There has to be give somewhere and if there isnt then you will most likely break something. This setup will be plenty stiff.
Old Jun 1, 2012 | 09:53 PM
ThumpnZ28's Avatar
A poly trans mount is horrible! I had one, and it was awful for vibration. Switched back to an OE rubber mount and couldn't be happier.
Old Jun 2, 2012 | 05:10 PM
mjs1012's Avatar
god a solid mm with a poly trans mount would be really stiff. i couldnt even imagine driving a car with both solid mounts
