oil filter question
Old Jun 1, 2012 | 05:13 PM
slammedc5's Avatar
Default oil filter question
Aloha gang,
I changed my cam and supporting parts a month again. 2 weeks ago I changed my oil and filter. Had a tick right from the start up. I always used a mobil1 filter before. No issues. This time I used a Wix filter. I think I'm going to change it out again
Old Jun 1, 2012 | 05:58 PM
SweetS10V8's Avatar
Wix is a good filter...
Old Jun 1, 2012 | 06:12 PM
slammedc5's Avatar
I agree, I use them in my twin Turbo BMW, but maybe they don't flow enough for the ls1, I was reading some threads on engine ticks after changing brands of filter. That's exactly what happened to me.
Old Jun 1, 2012 | 06:47 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Wix 51522 right here, from day 1. What oil are you running? When I switched AWAY from Mobil1 to Castrol Edge, my tick disappeared.
Then again, it sounds like you went to a healthier cam.... maybe it's just valvetrain noise? Filled the filter itself with oil before you screwed it in?
Old Jun 1, 2012 | 08:38 PM
slammedc5's Avatar
I switched from a mobil 1 filter to a wix, the tick was there after that. I checked all the rockers, there was no tick before the oil change. I soaked the lifters over night before installing them. The oil is clear and has zero foam/ airiation. I added a quart of lucas oil treatment, still there. I'll drive it for a few hundred miles and see what happens. And maybe change the oil
Old Jun 1, 2012 | 09:25 PM
99Bluz28's Avatar
Put a K & P Engineering Billet aluminum oil filter on it. I've been using one for about 5yrs now with no regrets at all.
Old Jun 1, 2012 | 09:29 PM
Zombiesoldier's Avatar
I have a thing about using factory filters. Mine will be getting one along with either mobil1 or Castillo Edge.
Old Jun 1, 2012 | 10:13 PM
slammedc5's Avatar
Cool, thanks guys. Im changing the oil mon. I work thus weekend. I'll look into a K&p, if theres any on the island. If not im going with the stock filter, and see what happens. Im sure most people wouldnt even notice the tick, big cam, straight pipes, but i hear it
Old Jun 2, 2012 | 08:24 AM
Paul Bell's Avatar
That's MISTER MODERATOR
What oil are you using?
Both filters are very high quality and almost identical in design. I doubt your tick is because of the filter.
Get that Lucas oil stabilizer outta there, it's just 80 weight oil with soap in it. It'll cause foaming-which you don't want.
http://web.archive.org/web/201009261...ucas/lucas.htm
Old Jun 2, 2012 | 11:17 AM
Anthony Williams's Avatar
What ^^ Said u NEVER! need any oil additives with synthetics man!
