Idle after heads and cam
Old Jun 2, 2012 | 04:21 PM
time3777's Avatar
Default Idle after heads and cam
I just finished with the install of a set of trick flow 220 as cast heads a Vengeance vrx5 camshaft and all the supporting parts. The car cranked and ran fine even idled good, after I ran for about 5 minutes idling I shut it off, now the car want idle correctly after I try to restart it. The car has not been driven or tuned yet. Its a 2005 gto with an ls2, any help with the idle would be appreciated.
Old Jun 3, 2012 | 04:13 AM
Undertow74's Avatar
just the cam and head or you swap intakes and TB also. The tune is def. off so i would work on that.........
