RPM dependent vibration, Crank Pully?
Old Dec 29, 2012 | 09:28 AM
arthropraxis's Avatar
I thought I would update that I fixed my problem. It was my clutch. I had a monster 3.5 and it had not been right since I put it in. I ended up replacing it with a stage 2 and finished it up tonight. It's butter smooth from idle all the way up. It's like driving a different car.
I don't know if the assembly wasn't balanced correctly or what but my vibrations are gone.
Thanks, for the update. I sent my flywheel/PP back to the manufacturer to be check for balance early on and it was balanced. I have this nagging feeling I didn't line up the spare hole in the flywheel with the partially filled hole on the crank. Would that be enough to create this vibration?
I plan on getting it tuned in a month or two. Fixing all of the vacuum leaks and tightening the header bolts decreased the intensity of the vibration so it may be a lean spot/timing issue in the mail order tune on the PCM that doesn't work with my motor.
Old Jan 1, 2013 | 10:51 AM
pkozera's Avatar
The original post said wrecked gto where was it hit? If in front and did the balancer whop very possible it could of bent the crank snout just a thought.
Old Jan 2, 2013 | 06:49 PM
It was T-boned. The vibration damper was fine and I replaced it with a new unit. Thanks, for the suggestion.
I did read on the corvette forum that some LS flywheels have weights added to them and some don't. If yours does not then it is 0 balanced and can be replaced with any 0 balanced flywheel. If the original flywheel has weights on it then you will need to transfer the weights to the new flywheel or have a machinist match balance the new flywheel to the old one.
I hope tuning fixes my issue. Taking the flywheel off is not high on my list of things to do, again.
Old Feb 10, 2013 | 07:39 PM
Swapped the clutch for a LS7 and all of my issues are gone.
Old Jan 20, 2014 | 06:20 PM
cool breeze's Avatar
what type of clutch were you using?
Im having the same damn issue with my ls1/m3 swap
