Engine paint
Old Jun 10, 2012 | 09:33 PM
wildcamaro's Avatar
Default Engine paint
Hey what's up, I figured I would post the pictures of my FINALLY completed engine with paint and all...I tried to copy the look of the lsx block with my 2005 L33 with 799 heads and an Edelbrock performer carb intake, I also am going to polish the valve covers to pay homage to 60s/70s big block/lt1 cars bc the engine is goin into a 4 speed 81 camaro ...I cleared everything including the bare heads and intake to protect everything...I'm diggin it...
I plan on swapping the valve covers for a set of hand polished ones I just started...here's a sample..
Old Jun 10, 2012 | 09:38 PM
JohnS Z28's Avatar
looks great man good work, have you considered painting the valve covers a matching orange with an LSX or Chevy logo on em?
Old Jun 10, 2012 | 09:58 PM
wildcamaro's Avatar
I haven't pondered that route but it sounds good...I've thought painted/polished and then sandblast a flat logo even...I got two sets so we will see
Old Jun 10, 2012 | 10:32 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Looks great! As the L33 has an aluminum block, what prep and primer did you use? I doubt if paint alone will stick very well on aluminum over time.
Old Jun 11, 2012 | 07:57 AM
wildcamaro's Avatar
After i brakekleened everything I rough sanded all the aluminum, then used some sand paper rolls on a porting bit to smooth out slag....then I went over whole block with red then gray scuff bad to smooth out. I then used 500 degree primer then 2 light coats and 2 heavy coats of Chevy orange followed by two coats of high heat clear...I know less paint is better but I couldn't help myself lol it keep looking better and better....finally I used one of those 3m plastic finger discs to do the pseudo machining look to accent and then cleared those spots...
Old Jun 11, 2012 | 08:38 AM
Paul Bell's Avatar
Nice! I think it'll stick.
Old Jun 11, 2012 | 12:20 PM
wildcamaro's Avatar
I'm not going to lie I had to go back and hand brush the front cover bolt heads since there was no other way to paint them without 7 days of masking the freshly painted front cover
Old Jun 11, 2012 | 12:32 PM
wildcamaro's Avatar
Old Jun 11, 2012 | 03:10 PM
Paul Bell's Avatar
Sounds very **** and nit-picking. Just like I'd do it!
Old Jun 11, 2012 | 03:48 PM
wildcamaro's Avatar
The engine bay is more important then the body in my eyes
Old Jun 11, 2012 | 04:07 PM
mjs1012's Avatar
that paint with the polished valve covers is gunna look killer. nice job op.
Old Jun 11, 2012 | 04:53 PM
wildcamaro's Avatar
Here is one of the valve covers after the red cutting compound...I got finish with the white now...
Old Jun 11, 2012 | 07:28 PM
gMAG's Avatar
Nice job!
I have enough extra bolts to try an alternative method.
Use extra bolts to install your front cover and paint to choice.
To get around having to mask the front cover in order to paint the cover bolts (or, vice-versa), I take a piece of cardboard and plant as many holes in it as there are bolts. Then the bolts are inserted all the way into the cardboard, then spray painted. Let air/sun dry for a few hours
We then wait for the wife to leave the house, so that the cardboard with bolts can be placed in the oven @ 250 degs. (Don't forget to turn the kitchen fan and open a window to withdraw the telltale odor!)
Replace the extra, painted cover bolts with your freshly painted cover bolts, one by one.
While installing the bolts, place a small piece of 3 mil plastic within the socket, so that your newly painted bolts don't get scuffed.
Old Jun 11, 2012 | 07:55 PM
wildcamaro's Avatar
Good call on the plastic inserts....I thought about removing front cover bolts one at a time because I didn't want my alignment of the front cover to be off...I def had to paint things 3 and 4 times just to be happy...brakekleen helped remove some of the paint in order to get a clean line...
Old Jun 12, 2012 | 07:39 AM
Unertl42's Avatar
looks good
