first ls1 header install and a small problem...
Old Mar 30, 2004 | 11:27 PM
bbz's Avatar
bbz
Default first ls1 header install and a small problem...
I've got all the bolts off except the last rear one on the passenger side. Any suggestions on the best way to get it out?
thanks,
jerry
Old Mar 30, 2004 | 11:31 PM
ATXCAMAROGUY's Avatar
Ratchet Wrench
Old Mar 30, 2004 | 11:34 PM
Z28Venom's Avatar
I got that one off by going removing it from under the car. It's alot easier to get to from under there if you have the car lifted high enough. But if you're doing it from the top and have already removed the coilpacks, then a ratcheting wrench will do the trick..
Old Mar 30, 2004 | 11:39 PM
FatZ28's Avatar
Yeah make sure you remove the coil packs, it made it alot easier on my friends car. If you have try from underneath the car.
Old Mar 31, 2004 | 12:14 AM
SapphireHawk's Avatar
I got this one from the bottom also. Iit is possible from the top if you have really long arms.
Old Mar 31, 2004 | 12:27 AM
SSEUL8R's Avatar
yep, get under it and take it out from the bottom
Old Mar 31, 2004 | 12:30 AM
onyxxtreme's Avatar
racheting wrenches are a must, when you have an 4th gen fbod
Old Mar 31, 2004 | 12:32 AM
bbz's Avatar
bbz
Originally Posted by ATXCAMAROGUY
Ratchet Wrench
When you say "ratchet wrench" do you mean a box end wrench w/the ratchet action? Also did you take the exhaust pipe before taking this last bolt off?
 Michael S. Palmer
Old Mar 31, 2004 | 12:34 AM
SSEUL8R's Avatar
yep, I got some metric Gearwrenches for Christmas. Some jobs are MUCH easier now. They make lots of LS1 jobs easier.
Old Mar 31, 2004 | 07:33 AM
Humanoid's Avatar
When reaching that bolt from the top you need to literally lay on the engine. To get the correct angle for your arm to go that far in. The same case with that sparkplug.
Old Mar 31, 2004 | 08:22 AM
bbz's Avatar
bbz
Default Thanks for all the suggestions...
I called it a night last evening until I get some new tools. I'll try again later today. Those coil packs are no fun to take off either... each one is bolted individually.
thanks,
j
