FAST 102 - What Do I Need?
Also, I forgot to mention you need to fabricate a bracket for your evap solenoid. I can post a pic of that if you're interested.
I had this issue in 2011 & found this pump solved the clearance issue.
Fast fuel rails work with their 102 intake
Nitrous on it.. Any helpful suggestions?
ls2/3 rails
Your injectors will work but you will need injector adaptors, call Fuel injector connection (FIC)
Go with a 92mm TB. They are plenty and WAY easier to tune. With the 102 I've heard of issues hitting the water pump but that's an easy fix. Either way get a 92mm
146032-KIT LS1
146021-KIT LS3/7
But those are the two part numbers I dealt with on my build.
