turbo s10 overheating
Old Jul 4, 2012 | 07:15 PM
T76s10's Avatar
Default turbo s10 overheating
when driving into town today it would overheat after driving for a while so I drove to napa. Got in the lot and took the cap off and got sprayed with radiator fluid, ouch. Figured I had too much so I put more in after it all blasted out but not as much as before and drove it again. Got to the gf's house and it got to 235 again. Put a little more in again and it was around 225 the next few miles to work. After the show, I drove home and as I got close to my house radiator fluid blew out of the cap and the belt slipped off. I bet it got above 240 but im not sure. For some reason there is ALOT of pressure in the radiator. My intercooler is a few inches away from the radiator so I was thinking that enough airflow was getting to it. With so much pressure and heat in the radiator I would think a blown head gasket but theirs no white smoke from exhaust and at wide open throttle the air to fuel ratio is a healthy 11.8 and with a blown gasket it should go lean and sound like it was backfiring, or atleast my cutlass did that. The electric fans work and I have a 160 degree thermostat so im out of ideas.
Old Jul 4, 2012 | 10:14 PM
sepsis's Avatar
Bad water pump, bad thermostat, or clogged radiator.
Old Jul 5, 2012 | 03:19 PM
T76s10's Avatar
T stat and rad are brand new. I'm guessing its something with thre intercooler bring only a couple inches away and not allowing airflow to the radiator
